Volume Bar Problem after changing theme
RISHABH_SALUJA
Hi guys. I've got a problem. When I applied new theme from sony select at first i thought everything was okay. But then when i tried to increase and decrease the volume of my device the volume bar on the upper mid of my device was gone. There's only a black bar appearing. I tried changing my theme to the pre-installed theme and rebooted my phone but it is still not there. What should i do? Hope you can help me with this.
3 REPLIES 3
profile.country.RO.title
_alexdon_
If you set a default theme and restart,it should be fine.
alexdon
Magnus_N
alexdon, this is only a temporary fix, since each time you restart the phone, the volume bar will revert to the faulty, black bar. So you will have to reload a default theme, restart and then load the downloaded theme again. Personally, each time I restart my phone, I load a default theme to avoid the bar hassle.
This is a bug really and should be fixed in the software.
/Magnus
_alexdon_
I know,you have to use only default themes to not get that.
alexdon
