Take a look in settings,maybe slow talk or mic noise suppression is enabled.
I am facing the same problem in Sony SP model, please give solution
Did you check what I told in the upper post?
I faced the same problem. This solution worked for me. Thank you.
Where in the settings is would I look for the slow speach setting. I looked everywhere on my SP last night. I do recall using it once when listening to a voice mail message, but can't see it anywhere in settings.
Yes everyone sounds a little tipsy now.
L
OK I finally found it ... Call settings. I will wait and see if brother-in-law sounds tipsy the next time we talk.
L.
This solution worked for me too thanks
Hi, thanks for the solution.
I thought everyone had been drinking-even at 8 in the morning!
The biggest problem, was that I sounded the same....Not too great for business.
Why this is set as a default, I cant understand.
Solution for Sony Experia Z2
Thanks again for the solution.
@alexdon wrote:Take a look in settings,maybe slow talk or mic noise suppression is enabled.
Nostalgia isn't what it used to be.
I know,I have had those on Z1 and they are pretty funny.
