Vibration when connection drops
PeterW1
Does somebody know if there is already an app for the Smartwatch SW2 that can make the Smartwatch vibrate if you walking away from your phone (so it would be a great app that for instance you do not forget your phone when you leave your house or friends after a visit). Because it is connected by bluetooth that have to be possible in my idea.
5 REPLIES 5
Johan
The SW2 should vibrate when it drops connection with your phone.
Have you tried leaving your phone inside then go outside with your SW2? Slightly_smiling_Face
machmanbt
Hi
The watch should give 3 short vibrations on disconnecting
if you wanted you could also use tasker to create a task that makes your phone play a loud tone on disconnection too
Thanks
www.smartwatchnews.co.uk
PeterW1
Thanks for the tip of the program Tasker, sound would be better than short vbrations. Anyway i am happy the possibility is there!
PeterW1
I tried  and indeed the Smartwatch SW2 vibrates when connection drops and also vibrates when connected. The idea of changing vibration to sound  by the program Tasker of another member is also idea wothwhile trying.
ScottXe
New
Hi Machmanbt, it sounds very useful function to have loud sound on disconnection.  Can you provide the setup procedures.
