i have problem in my phone , its not vibrating on calls or messages.
as the setting "vibrate on ring " is on..
so, kindly help me to solve my problem..
Make sure its not a hardware issue. User Xperia Diagnostic tool. You can download it from Google Play.
https://play.google.com/store/apps/details?id=com.sonymobile.androidapp.functiontester&hl=en
If it works in Xperia diagnostics. Check your settings so you have the vibration turned on. Also remove the battery from the phone for a while.
If it doesn't work in Xperia diagnostics, you should have the phone examined by a service center. Please contact local support for more info:
