Vibration mode is not working for Xperia ARC. Any suggestions...
Hi, could be a setting issue .... Goto Settings>Sound, play with Vibrate selection with available options there.
Keep us updated.
Thanks for the quick response.
I tried it but it is not working.
Thanks
turn off you phone > remove the battery for 5 minutes..
insert it..switch on the phone and see if problem remains or not..
if the above doesnt helps
update your phone software thru this..
http://dl-www.sonyericsson.com/cws/download/1/110/61/1309763183/Update_Service_Setup-2.11.7.13.exe
back up all your files before doin so..
if its a software glitch it will be solved by the above software..
if that still doesnt works , go to your service centre nearby and get it checked..
See if phone passes this test .... Tap Dialer, key in *#*#7378423#*#*, this will launch the Service Menu. Select Service tests>Vibrator, see if phone vibrator is working.
If yes, proceed to Software Repair. If no, proceed to the local SE Service Centre for repair.
Keep us updated.
