Hi i have problem. My Xperia SP has vertical lines all on the screen... they are visibly a lot, especialy on white background. I tired RMA, but thats was rejected. What i have to do ? On low-ends isnt that problem ( brother have Xperia M) so why on mid-end phone like this ? its rally disturbing.
mmm273,can you take pictures of it?We might want to see it a little bit closer.Thanks.
its not much visible on photo, but you can see it... real life is worse
Thats bad.I suggest you to contact Sony first before bringing it to Sony Center.I think it is more to software related issue rather than hardware.
no its not a software... im sure its HW failure, but as i said, its been on RMA and they said - "its a feature, not failure"... i dont know what now, because, i spen my money for failure phone...
I also contacted SONY and waiting for they answer. If its realy "feature" and not "failure" its my last SONY device.
Becasue this is not fair for me as customer.
Did you put any screen protectors?
no, on screen was foil with that red stripe ( prepurchased foil, no screen protector).
Mine is a bit different.
I will try to make a photo as well.
It's visible in bright sun light better, when I tilt the screen a lot.
I thought it's a feature, but wanted to double check.
The lienes are very symmetric, hollow and seems to be under the glass. Grey lines with some texture.
I have no issues with touch sensitivity and phenomenon is not dedicated to white screens.
I thought it's may be the ASF (anti shatter film), but I do not really know if SP has it or not.
Different sources, different answer.
Oh man,only now i saw the picture,i am sorry to say this,but that actually really is a feature...It is part from Corning Gorilla Glass 2(but don't know how it functions).That also exist on my phone,but since i put the brightness a little high,i did not experienced it.Don't worry mate,its normal.
