Hello
I've been using my Xperia Z for a few weeks, and I'm very satisfied with the quality of the handset. I think I've made the right choice
The only thing I see as a minor problem is that "There are tiny vertical lines --------- all over the screen surface which can be seen when the screen is off or under direct light " Especially it affects the view under the strong sunlight.
The panel is Sharp.
Anyone wtih the same issue? Do I need to send it to the technical service?
Thanks.
its not an issue that's the digitizer, it's normal
