Would Sony care to have a look at this screenshot and suggest what might be causing this immediate 5-7% battery drain?
The phone is now about one month old and battery life is good considering the amount I use the phone. A normal charge lasts in excess of 24 hours easily.
The phone is in "as new" condition and has not been droppped - one reason that batteries can lose large amounts of charge instantly.
A.
I had the same problem but SOLVED it!! I went to the sony center and he downgraded the software to the 162 firmware which helped a lot also i found some neet tips while searching online. here
http://40marks.com/xperia-u-xperia-p-battery-problem-solved/
