Using the application on PC
Deep17
I would like to use the Apps when connected to PC from PC. I have a xperia SP C3502 & have installed PC companion too. But PC companion only helps storing and retrieving the data from and to PC. I want to use apps from PC- any suggestions?
Er_Kannan
This is not possible. You can Install an android emulator to view and test the applications. This need installing of android sdk and all.
Check this link http://developer.android.com/tools/help/emulator.html
