Hi. I NEEDED SOME HELP. I WANT TO PLAY VIDEOS ON MY PHONE BUT I WANT MY BLUETOOTH EARPIECE TO HAVE THE SOUND COMING OUT OF IT. IT IS ALREADY CONNECTED AS A PAIRED DEVICE...BUT WHENEVER I PLAY MUSIC OR A VIDEO THE SOUMD COMES FROM THE PHONE...PLEASE HELP I HAVE A SONY VIVAZ PRO
Does your headset work OK for making and receiving calls?
yea it works perfectly fine...i used to use the same headset on my old phone to listen to video audio
i HAVE to figure a way out to get this to work! or i will have to return the phone
it is crucial if i want to keep this phone and be happy
This may be because this headset is not compatible with the Vivaz for audio streaming: check to see whether your phone has Audio streaming listed in the BT Services available for this headset.
Which headset is it and is it a stereo bluetooth headset, or just an ordinary BT headset? Which was your old phone?
i have 2 bluetooth normal headsets: Motorola H375 and Motorola H555
my old phones were LG Xenon and Sony Ericsson T715A
These headsets are mono headsets and although they work OK for calls on the Vivaz, they are most probably not compatible with the Vivaz for audio streaming, in order to listen to music/video.You would need a compatible Bluetooth stereo headset for this.
Does the Vivaz give you information on the types of BT Services available with these headsets?
no it doesnt
An example of the type of BT stereo headset that allows Audio streaming and is compatible with the Vivaz is the HBH-DS205, details of which you will find on the SE website and if you want to buy it, I would suggest Amazon.co.uk
that looks expensive
