usb tethering problem with neo v
The driver cannot be installed properly on windows xp, in device manager sony ericsson sa0102 remote ndis based device #2 is showing not install.
see the picture below. please help
4 REPLIES 4
Markus1
Leader
Do you have PC Companion installed in your phone?
Are you having problems when connecting in both MTP and MSC mode?
yes i have PC Companion installed.
Markus1
Leader
I asked you two questions. Please answer the other one too.
Have you tried to switch to a different USB port and see if the drivers are installed correctly?
Avoid using any shortcuts/hubs. Connect the cable straight to one of the main USB ports on the PC.
I have the same problem.
I have the  PC Companion on the computer. It recognizes my telefone name and model correctly.  And I can connect my phone as MTP and MSC mode.
I tried to use other usb ports. But I could not solve the problem.
I have xp SP2 installed on the computer. I have not upgrade it to sp3. Because it slows the computer too much. ( Maybe sp3 pack is necessary. I do not know!!! )
I got the same installation problem but Sony Ericson sa0102 ADB interface driver does not seen on my device manager.
I have had 4.03 and I have ISC 4.04. Still can' t solve problem.
What can I try more. ( Maybe another computer ?)
