USB tethering had been working just fine before. I try it today and it force closes as soon as i enable it, every single time. This is really really frustrating. I already rebooted the phone, still no help. I need this to work. Any help?
Try performing a system repair as this will often fix issues - This will factory reset your phone
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
I'm not sure what answer you were after - As a user support forum and without knowing what apps are on and what they do etc then that is about the best I can do - I suppose you could try a settings reset but as you have said this may not be an option as this will not erase data but reset your personalized settings
If you want to try a settings reset then open Settings then Apps and swipe to All then locate and open Setings - Tap on Clear cache and data and then reboot and test
Didnt work.
How could a built-in app like this break so bad? Would a logcat help? (or is that more for the XDA forum types...)
More for XDA
