You will have to reformat it (FAT32 or exFAT)
Uliwooly is correct, however please make sure you back up the data on the drive to a PC first if possible.
I have asked about USB storage/OTG cables without much help. So I've been experimenting. the tablet doesn't seem to have issues with USB drives that can be connected directly to an OTG cable.
If you put a cardreader in the mix, then all bets are off. I have not been able to connect sdhc /CF cards with a card reader. It just does not recognize them.
Hope this helps.
Partha
