hi, my xperia u (GB) cannot connect to pc as i dowload update for driver, but it shows a yellow triangle on it. I do not want to upgrade it to ICS. kindly sort out the problem. everytimes device driver failed to install.
That's not a Sony issue if your Pc won't install the driver
my usb nd pc don't hv problem as the same usb can connect other device on same computer, also i tried diffrent usb as well as diffrent pc but problem is i.e. in my mobile.
