Tablet Z 16GB WiFi
10.31.C.0.136
I've tried tried two different usb drives with two different OTG adapters all of which work fine in other devices, but when plugged into the tablet do nothing. I was expecting the drive to be automatically mounted. The option in settings to mount external USB storage is also greyed out.
Any ideas?
Thanks for the reply. It is a normal usb flash key. Power draw should not be an issue.
Yep, no luck.
what format is the drive ? ( FAT/FAT32/...) and what size ?
FAT32, multiple sizes tried (4, 8 and 32 GB).
Sorry I run out of options. I tried now on my tablet with an 8GB FAT32, using OTG cable from an old Nokia Phone. Mounts normally. Hope someone more knowledgeable in this forum ( there are plenty..) can help you... My developer options are all turned off, btw.
Thanks. What firmware version do you have?
4.2.2 Unfortunately !
