URGENT HELP NEEDED
hashamahmed
URGENT HELP NEEDED
sir i just updated the my experia SP
but after that it cant switch on..
keep showing sony logo and then reboot again
how can i cope with this problem?!!
i cant use my phone now!!!!!!!
Please reply
2 REPLIES 2
Thommo
Genius
1st try holding power and volume up until you feel 3 vibrations 1 after the other - Then try to boot your phone - If that still fails then unfortunately you will need to perform a system repair using either PC Companion or SUS found here - You will need to perform the 1st part of this reply then if using PCC click on Support zone then update my phone/tablet then in blue click on repair my phone tablet - Then when prompted hold volume down and connect your usb cable remember your phone should be switched off to perform the repair
dm84
pop open the back of the phone , hold dow the off button for 8seconds wait for the device to vibrate 3 times then perform update again via sus (sony update service)downloaded on your pc
