Update Problems
Update Problems
Ok i have had my arc for around a year now and have never been able to update it. i habe pc companion and all that on my laptop but always get an error message saying it could not connect to my phone and to restart and try again. done this countless times. does anyone know what the problem is?
4 REPLIES 4
try Update Service (SEUS)
http://dl-www.sonyericsson.com/cws/download/1/110/61/1309763183/Update_Service_Setup-2.11.7.13.exe
if you want to manually update your phone
2.3.4           4.0.2.A.0.42  (LT15i/a & LT18i/a)
2.3.4            4.0.2.A.58    (LT15i/a & LT18i/a)
http://talk.sonyericsson.com/message/130711#130711
2.3.4          4.0.2.C.0.5   LT18i & LT18a (works on LT15i/a too)
http://talk.sonyericsson.com/message/133669#133669
Make sure you backup everything
Use one of these links to download the
Backup & Restore app
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
How to install it
You need to
download IO File Manager
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
open your phonebook
on your computer
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
or your SMS use
"backup & restore SMS"
or for your MMS use "Save MMS"
Call Logs
And for call logs this is great
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
market my library.JPGmarket my library 02.JPGmarket my library 03.JPGmarket my library 04.JPG
My Phone Explorer
https://market.android.com/details?id=com.fjsoft.myphoneexplorer.client&hl=en
if you have a lot of sms/mms the backup & restore will take forever or might not backthem up corectly
both apps above Backup SMS +    and    backup & restore SMS are great, this last one it's really fast
an even Easier alternative
download the app, transfer it to your SD card
Download Apk Manager
W251bGwsMSwxLDEsImNvbS5tYWdtYW1vYmlsZS5hcHAuYXBraW5zdGFsbGVyIl0.
open "Apk Manager" and voila select the apps that you wan't to install
another alternative
download the apk on your computer, send it to yourself through email, make sure you send it to your Gmail
now on your phone
wait for the email, once  you get the email, open it, and instead of downloading the attachment it will allow you to install it, voila, done
or
