Unlocking from network
Throwdy
anyone in the UK know how to unlock/unlatch a tablet from a service provider as my one has not got a clue how to.
9 REPLIES 9
Hampus
First of all, you need the unlock code which your current service provider should have. When you have this code (to unlock the network), you just need to insert a SIM-card from another network provider and the Tablet will ask for the unlock code. When you enter it and save, the Tablet will be unlocked and you can use any operator.
djb1
Hi,  Please allow me to ask, how do i know if my Z1C is latched to the 02 network. I bought it from carphone warehouse on a 2year contract tied to 02. I wish to change networks very soon and have attempted to unlatch using the 02 App. Received a reply from them stating "cant be done, this is not a 02 device".  This prompts the question, where do i go from here. am i correct in assuming that the phone is unlatched or could it be that their reply is because i am not using the number that was supplied with the phone. Hoping you can help with a solution, thanks
Hampus
Hi djb1,
You can either mount a SIM-card from another network provider and when the phone has powered on, you would be asked to enter the code to unlock the network. If it's locked to a specific network, it will only work with a SIM-card from that provider.
Or you can check the service menu. Go to the dialer and enter *#*#7378423#*#* > Service info > SIM lock.
If you see that the clams are marked with an X (for exmaple [X] network), this indicates that it's locked.
djb1
Hi Hampus,
                   Tried the latter and it came up with five sub headings under Sim Lock, each one had a 0 at its side which tells me it is unlocked.  thanks a lot mate, you are a Top Guy.
Hampus
The number that you have, indiciates how many tries you have left to unlock the phone. Did you see any mark inside the clams/brackets that I mentioned: For example, [x] Network 0? If you do not have any marks inside the clams, the phone is unlocked. The number should then also be shown as zero.
djb1
i,ll show you what's there.  [ ]   network            0
                                           [ ]   network subset   0
                                           [ ]   service provider    0
                                           [ ]   corporate          0
                                           [ ]    sim         0
          so the above means i am unlocked, yes.  when you say a number depicts how many attempts one has left to try and unlock i assume this number would be inside the bracket, and you are not referring to the zeros, because i have not made any attempts to unlock.
Hampus
Yes, based on this information your phone is unlocked. :smileysmileythumbsup:
The bracket is the one that shows if the phone is locked, but it will not show a number just an "X"-mark inside the brackets. And the number (in this case a zero, if the phone was locked it would normally show 5 instead of 0) indicates how many tries you have left to unlock it.
If the phone has been unlocked or has never been locked, the number will always show 0.
djb1
got  there in the end just about:smileybeat_up:thanks for your patience
Hampus
No problem, you're welcome! Slightly_smiling_Face
