unlock pattern password forgotten..help me out please..
pratibha907
hello sir i hv forgotten my password so suggest me what should i do...??
i have tried this all thing but didn't worked...
1- google account login failed because of no data connection(netpack is disabled)..
2- tryed to udate with pc companion but didn't worked cuz i had updated beforoe only from jellybean 4.1.2 to 4.3 jellybean..
pls pls pls pls help me out as soon as possible cuz suffering this problem from more than 2 days...
Thommo
Genius
Perform a system repair - This will factory reset your phone meaning all data etc will be erased
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down - This should start the repair or reformat process
