UNLOCK AND THEN RELOCK BOOTLOADER IN NEO V
sandiprc2010
CAN ANYONE TELL ME HOW TO UNLOCK NEO V BOOTLOADER.
IS THERE ANY WAY TO RELOCK THE BOOLOADER?
9 REPLIES 9
sandiprc2010
THANKS FOR THE REPLY.
NOW THE ABOVE METHOD STATES UNLOCKING BY UNOFFICIAL METHOD(TEST POINT).
NOW I WANT TO KNOW IF I UNLOCK BY OFFICIAL METHOD, IS THERE ANY METHOD TO RELOCK BOOTLOADER?
I WAS GOING THROUGH :http://www.theandroidsoul.com/guide-how-to-relock-boot-loader-on-xperia-arc/.......   THIS.WILL THIS BE HANDY???.....OR ELSE CAN U SUGGEST ANY OTHER METHOD?
this is how, btw, don't use upper case, upper case = screaming
http://forum.xda-developers.com/showthread.php?t=1134335
http://talk.sonymobile.com/thread/44888
Nabeel
the method that i posted above to relock is for both, unofficial and official
i suggest you go for the official way of unlocking the boot
sandiprc2010
thanks once again.
if I go with the official way of bootloader unlocking (http://unlockbootloader.sonymobile.com/)
and then relock with the method mentioned ...http://forum.xda-developers.com/showthread.php?t=1134335.
will my phone show lock bootloader status by dialing *#*#7378423#*#*
also i want to know will my neo v be as good as now (with locked bootloader)
Nabeel
Your phone may not be as good as it is now....
Bootloader once unlocked is unlocked for forever.
The way to relock not actually relocks it but it's a process by which you flash a files that fools pc companion and other softwares that the bootloader is locked
After locking the bootloader you won't be able to use the stock Track ID forever
May i know why you want to unlock the bootloader ?
sandiprc2010
actually i want to install custom rom availaible in xda developers.trully speaking after upgrading to  4.0.3(now 4.0.4) my handset has become increasingly slow and above all sometimes it heats up (opposite to flash).
so i am planing to taste the icecreamsandwitch through custom rom.
soumikray
Hi Nabeel,
I was trying the official way to unlock Bootloader explained here (http://unlockbootloader.sonymobile.com/). Step 13 here says the following:
13. On your computer, you will be asked for drivers. Point to the usb_driver folder where you placed
      the android_winusb.inf-file, and select the Android Boot loader Interface-file.
But when I am giving the path to the usb_driver folder windows (Windows 7 Ultimate x64) says driver not found.
Can u plz help me with it.
I want to install CM10 Thats why I was trying this as suggested in the guide here: http://forum.cyanogenmod.org/topic/63781-tutoneoneo-v-how-to-install-cyanogenmod-10/
DebGouav
Hy nabeel. I want to relock my neo v 's bootloader.it was unlocked by official method.if sony service center will fix this or not ?
