Under water touch screen problem
xperia_z_1
my z1 display touch not work in under water. plz help
13 REPLIES 13
The touchscreen its NOT supposed to work underwater
profile.country.RO.title
_alexdon_
Yes,uli is right.Under water the touch goes crazy.
alexdon
kaslokesh
Yes... Same here too!!! When mobile is immersed in water its display starts not working... When you take it out of water, still the problem persists until you press lock it by pressing lock button and then unlock it...
Is this software bug or is it display problem???
_alexdon_
There is no bug,no display issue.Water does this to the digitizer.It needs some time after taken out of water until you can use it again.
alexdon
The screen will work with few drops of water but not a lot, I've tested this, it seems that small drops its ok, it will work just fine but if the screen its water saturated it will stop working, which is normal.
xperia_z_1
my problem solved!! i needed to took some photo in under water. In underwater the screen touch not worked but the shutter button still work. u can take picture to use the shutter button
_alexdon_
Of course,you can use the button.
alexdon
if you don't want to use the shutter you can use an app like this
https://play.google.com/store/apps/details?id=am.tir.z.proximitycamera
and use the proximity sensor
todorov82
I have problem when wather touch the screen pfone response on drops ??
