Unable to switch on my phone need some serious help
Tay1
 everyone, i got some issues while switching on my phone. Today my phone has automatically downloaded system update, after completion i installed that update and few minutes after installation, phone restarted and shows this massage "The software update failed. Make sure that your phone is connected to computer and try again."
I connected my phone to the computer but still shows the same message and shuts down automatically and im not using any custom recovery.
what should i do now??? Please help me with that..
4 REPLIES 4
Thommo
Genius
Try performing a system repair using PC Companion as this will often fix issues - This will factory reset your phone and erase all data
Tay1
thanks for the help, but my phone is not switching on, so how come i turn off my phone and connect to PC through PC Companion?. I tried to connect my phone using PC Companion but it didn't connect. Phone turns on and shows "The software update failed. Make sure that your phone is connected to the computer and try again" and shuts back down.
Thommo
Genius
@Tay1 Your phone must be off and as per the instructions and using the repair mode you connect your device when prompted with your phone switch off holding volume down and then connecting your USB cable which enters your phone into Flashmode and begins the firmware re-installation process
Tay1
@Thommo thanks for the help. I followed every single instructions as you gave to me but it didn't worked. I also tried using recovery mode to enter flashmode for firmware re-installation but it didnt worked out. Results are same nothing happend. Is there anything else i can do?
