I have a problem with my phone i open camera and capture snap, when i click capture its throw me on main menu.
I have done soft reset the phone but no improvement
Kindly Advice.
which phone do you have?
I have W580i
do you have enough space on your SD card?
currently i have only phone memory and its 16 MB free.
were you able to capture pictures before? delete some pictures and see if you can take new pictures
I have deleted all picture but same result.
currently 16MB free space are available in my phone memory
If the application crashes and throws you to the main menu it sounds like a software issue in which case I would have to advise that you run an update via PC Companion:
http://www.sonyericsson.com/cws/support/mobilephones/downloads/subject/pccompanion/w508?cc=gb&lc=en
I don't know if it's compatible with your phone but try this out
My Phone Explorer
to backup everything then repair it with either PC Companion or Update Service
Update Service (SEUS)
http://dl-www.sonyericsson.com/cws/download/1/110/61/1317636927/Update_Service_Setup-2.11.10.7.exe
Unable to download software from site do u have setup file so send me.
