Could you please inform me whether the card at the site http://www.amazon.com/gp/goldbox?ref_=pe_36900_22392340 is compatible with ericsson txt? Generally which cards are compatible with it? Thank you.
http://www.sonyericsson.com/cws/corporate/products/phoneportfolio/specification/txt Yes it should be because as you can see, the Txt is compatible with MicroSD cards up to 32 GB.
Thank you. The fact that it is a "MicroSDHC" card has anything to do with its compatibility? Thank you.
From what has been mentioned before on this forum, MicroSD cards from 4GB upwards are all MicroSDHC anyway, as the HC stands for High Capacity and the SD for Secure Digital. Compatibility should not therefore be an issue, nor should its class (Class 10 from your link), as there is no mention of a class restriction on the SE website for this phone.
Thank you very much.
No worries.
I just bought this 16gb micro sdhc class 10 card for my CK15i Text Pro
So the answer is
- they work and very fast too!
