TX Battery drain out
Lionelp
I just got my Xperia TX last week,but I have one issue with my phone, the battery drains really fast. I always use internet & wifi. I can get around 4 to 5 hours before it drains out. Is this normal? Any suggestions guys?
4 REPLIES 4
Daloch
First you have to check is if you have JB installed.
If so, it is a well known issue... the battery it's only up to those 4 or 5 hours.
So, til the moment that Sony decide to fix this issue (same as all the others), it's easy... you have a smartphone that you cannot use as a smartphone.
Don't worry, since it was update to JB, the battery became a cra*.
If you have installed the last IC update, then it's not normal, so take it back.
Think this. With IC, I was used to charge the battery once per day (sometimes once every a day or a day and a half).
Since the update to JB, I have to charge it 2 or even 3 times per day.
miffy
I've had no battery issues now it's had a few weeks to settle down.
5 hours could be normal , depends what you're doing on the net.
Lionelp
Am still using the old version which is ice cream sandwich.
Daloch
With the last update of IC, your battery should last much more time (unless you download a lot or play HD videos or play games all the time).
With a normal use (mailing and others), my battery took much more than 5 hours with IC.
Besides, think in what miffy wrote. It take one week or so for the battery to work fully 100%.
