My old phone was a nokia and the blue tooth in my car is a vivid and had no trouble connecting to the vivid but cant now any suggestions
Can you still pair the phone to it? Which phone is it and could this simply be a compatibility issue?
First of all, what kind of phone do you have now?
Make sure to check what bluetooth profiles your bluetooth unit in the car uses so we can check if it should work or if it might be that the phone doesn't use the same one as the car does. That might be the case.
My old Nokia synced every time to the car. But I find that my contacts are requested from the Expieria U some times; more so if the battery has run down.
Why does it not tranfer phone book automaticly?
