Bonjour à tous,
J'ai une tablette Sony XPéria Z sous android 4.3. Il y a un logiciel Sony bien utile: Transfert fich version 1.3.2 de Sony Corporation qui permet le transfert dans les 2 sens mémoire interne <--> carte SD.
Sur mon tout nouveau smartphone Sony XPéria Z1 compact, sous android 4.3, lui aussi, il n'y a pas cette application. Ou peut-on la télécharger ?
Car j'ai installé le logiciel TwoNav avec plusieurs Giga de cartes au 1/2500. Je voudrais le transférer sur la carte SD (64Go).
Merci pour vos précieux conseils.
Hello everyone,
I have a Sony Xperia Z tablet android 4.3. There is a very useful software Sony: File transfer 1.3.2 version of Sony Corporation that allows the transfer within 2 internal memory meaning <-> SD card.
On my new Sony Xperia Z1 compact, android 4.3 smartphone also, there is no such application. Where can I download it?
Because I installed the TwoNav with several Giga card 1/2500. I would like to transfer it to the SD card (64GB).
Thank you for your valuable advice.
Pierre
I am sorry,but apps cannot be moved to SD on your Z1.
Ok, thanks for your answer.
Do you know why on Sony XPeria Z1 compact it is not possible to transfert appli from internal memory to SD card ?
I thought it was available on all android smartphone...
Best regards,
Pierre
On Sony phones it is not available yet.Rooting is required(which voids warranty).You can contact xperia care for more info,I am just a forum mod:
Thank you for your response
Pierre.
You are welcome.
