transfer data to sd card problem
athi206
Every time I try to transfer data to sd card,it says memory has unfortunately stopped, plz fix.. Or give me an idea
15 REPLIES 15
profile.country.RO.title
_alexdon_
I am sorry for the inconvenience.No problem.
alexdon
Sam
Legend
Legend
It may be worth contacting your local Xperia Care team to see if they can assist in getting you handset through to the authorised agent if there is not one nearby.
What are your thoughts about this forum? Let us know by doing this short survey.
Davide777
How do you low level format the sd card?
I have the same issue and is infuriating.
_alexdon_
Download a low level format tool from here.Be careful,after a low level format,nothing can be recovered.
alexdon
NickBuisseret
Explorer
I gave up and decided to use File Commander app that came pre installed. I transferred some audio files then checked the storage settings page and out of habit tried the transfer button and it now works..!? Don't know if that fix will work with anyone else but File Commander is a good option (you just select file,copy, then find destination folder on Sd card and paste..then delete from internal storage. Or cut and paste but I didn't check if you can cut).
_alexdon_
Media is supposed to work ok,apps cannot be moved.
alexdon
