Hi all
Everytime i try to use the track id on the X10 i keep getting the following error
Error. Please try again later.
Ive had the phone a few days now and this has not worked for me once. Anyone any ideas how to fix this?
Thanks
Anyone have any idea how i fix this?
Thanks
I'm sorry to hear you are having problems. I would recommend following the below steps which should stop this error for you:
1. Go into Settings.
2. Tap Applications.
3. Select Manage Applications.
4. Tap Track ID.
5. Select Clear Cache.
I hope this helps. Let me know how you get on.
Aimee ive tried that but its still not working. When i press the record button on the track id it just records for a second or 2 then i get an error saying please try again.
Any ideas?
I have that same problem with Zylo's Track ID.. It worked fine about 2 months, but not any more.
I have that same problem with Arc S when try use Track ID
Hi all,
Have you all tried the steps I have provided above?
Have any of you recently updated the software in your handsets or tried resetting the phones?
What do you think about this forum?
Let us know by doing this short survey: http://surveys.opinion-8.com/SE/SF/en
not worry about this error , you can go to play store > sony application > TrackID and download it !! it's work great!!
it doesn't work bc you unlocked the bootloader, the DRM files are gone forever
cache data was already o.okb. What else can I do?
