I have a problem with my Touchscreen Xperia X10 mini pro it start not work anymore and sometimes it work for some minutes and than stops again...
Not sure why... it did not fell, nothing happened abnormal... Just had this problem after a download of candy crush and played it for a while...
Restart the system... re did all the intructions of the site and still not work...
Any software repair specific for it ???
Thank you !!!
Angel
Hi, see if software repair with PC Companion or Update Service helps.
Be aware that this process will erase phone data completely.
Thank you !!!
Yep... already lost all data on the previous system up date...
I'll will try again...
Thank you so much !!!
No problem, let us know how it goes.
Don't forget to mark correct answer as Accepted Solution.
If you find the post helpful, press Kudos.
