Hi 238uuu,
Welcome to the community,
Sorry to hear that, hopefully, I can help resolve this issue for you.
The first step I suggest taking is to perform a diagnostics tests with the device, this will help determine if the issue is related to hardware or software.
Menu > Settings > About Phone > Diagnostics > Test > Touch Screen.
Please go through the test and if you don't mind letting me know here what the results were.
That is not entirely true, the diagnostics tool will let you know if any screen touches are occurring without you touching the screen. The second thing you should now try is moving through to Safemode and testing it with normal use. if the issue has stopped in this mode, then the likely cause is related to a third party app.
Let me know how you get on.
I have the same problem. It touches double, or thinks I'm touching twice or multiple times while typing. It happens sometimes a couple of times a day, sometimes I can go a day or two without any problem. When I'm trying to hold my button to sellct a number, it will only type the letter many times. For example when I'm trying to type 2, it will write qqqqqqqqqqqqqqqqqqq.
I've tried to do a factory reset, software repair, I even had a boardswap due to a different problem.
I've also noticed this several times.
I always use swiping to type text.
On rather regular basis when swiping, it breaks up and my swipe is interrupted, resulting in wrong words.
This is mostly noticeable when swiping for long words.
It doesn't happen all the time, but enough to be annoying when it happens.
In the beginning I thought I lost contact with the screen when this happened but it has been too much to be like that. Especially i pay more attention to not lose contact when it happens, but it keeps happening for some time and than it's ok again.
