touch screen responsive problem
Axcelctw
I found out m2 have touch screen responsive issue and some are experiencing as well. See this video
Also I found out that problem didnt exist when in landscape mode. Thi convince its a software. Kindly tell the sony engineer to fix this issie. Tried factory reset and pc companion so dont tell me to do so. The issue is still there.
http://youtu.be/QvL4ZSkWrZs
4 REPLIES 4
sheko_2000
i also have the same exact ptoblem
but i dont know if it because the kitkat upgrade or not as i didnt try it with the previouse release !
profile.country.IT.title
Michelasso
I just bought my Xperia M2 D2303 2 weeks ago, it has the lastest OS KitKat 4.4.4 and the touchscreen seems a bit faulty indeed. Swping in the keyboard randmly it breaks the words. I also tried testing the touchscreen dialing *#*#service#*#*, going to service test/touch screen and I see that when I swipe fast vertically the drawing line jumps. But randomly again.
Checking in the internet this appears to be a common problem with most if not all Xperia phone models. I mean, really Sony? I bought an Xperia because to me Sony is synonimous of quality, this is a real let down. Also because from what I've read some people sent the phone to be repaired and after getting it back it still had the issue.
Superdin
Just go to settings about phone and tap build no then developer option should be unlocked.
Then go to devoleper options enable it and swipe down u should see force gpu2 rendering on that function
Michelasso
Nope. I just tried. Same thing (and that carried to Lollipop 5.1.1). I've noticed one thing though: while charging it's fine. I wonder if it is because it gets warmer.
