I am Using Xperia SL for the past 2 years. From Yesterday my phone touch in the Status bar is not working. Its not working in portrati mode, when rotated to landscape mode its working fine. any solution for this problem is much appriciated.
Hi Balu991,
This may be related to Hardware, however on the off chance that this is related to software, I suggest a software repair on the device.
and install it on your PC.
4. Phone Software Update.
5. Start.
6. Repair Phone
7. Continue
8. Accept data removal
9. Next
10. Wait for prepare
11. Select Phone
12. Follow the connection steps
I hope this helps.
