my phone sometime will randomly click anything on the screen, & sometime the touch is not sensitive,like when u scroll to down,but the screen will move to left or right,or sometime stucked there.But when i off my screen & reopen it,it will back to the normal. (i wonder is it the screen protector fault?)
Anyone have experience this before?
well..remove the protector..
tell us if the problem remains or not..
if that doesnt solves the problem..
repair your phone through this..
http://dl-www.sonyericsson.com/cws/download/1/110/61/1309763183/Update_Service_Setup-2.11.7.13.exe
repairing will delete ll the phone data so backup all your files before doing so..
keep us updated..
I used my Xperia play for around half year already, but recently i found out that the 1/4 of the right touch screen is not functioning. I had run through the Touch screen test and the test also shown that part of touch screen is not responding. is there any ways to fix this other than sending it to warranty?
just the above suggestion (SEUS)
how do i run the updates? i try to run it on the computer, it download then install and create shortcut, but when i click on the shortcut, there appears to be error....
Install the program above Update Service on your PC reinstall your computer, run it and done
Make sure you backup everything
Use one of these links to download the
Backup & Restore app
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
How to install it
You need to
download IO File Manager
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
open your phonebook
on your computer
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
or your SMS use
"backup & restore SMS"
or for your MMS use "Save MMS"
Call Logs
And for call logs this is great
An easier way to install the Backup & Restore app
download the apk on your computer, send it to yourself through email, make sure you send it to your Gmail
now on your phone
wait for the email, once you get the email, open it, and instead of downloading the attachment it will allow you to install it, voila, done
or
thank for ur advice, i had sent my phone to service center for warranty...
ok , do tell us if the problem is solved..
