Since today I have a problem with the touch screen.
It's just not recoginzing properly the placement of fingers on the screen.
This makes it a rail pain to write a message on the keyboard. For example I try to hit one letter and 2 or 3 will activate at the same time.
An other example would be in the Facebook app it's almost impossible to hit a like button.
There is no screen protection on the phone, nothing changed in usage / apps etc..
Tried the different kind of resets suggested in the Sony nothing helped.
Anyone with the same issue? Solution?
Never happened before, phone never went into the water etc..
Hi jamieb81,
Have you performed a touch screen test?
Menu > Settings > About phone > Diagnostics > tests > Touch screen test.
Let us know the result.
Yes I just did that, and it's not working properly.
The wiping just doesnt follows my finger like it should. especially upwards.
I cant wipe out the form shown properly
Does your phone has a protective case and/or film? if it does, remove it > restart the phone > test it again, if it doesn't then you should contact your local Xperia care
That is unfortunate, this could be a software related issue, try performing a software repair on the device first.
Make sure to back up first
Here's how to run the repair on PC Companion:
2. Phone Software Update.
3. Start.
4. Repair Phone
5. Continue
6. Accept data removal
7. Next
8. Wait for prepare
9. Select Phone
And Bridge for Mac:
2. On the Main Window select "Xperia > Repair Xperia Device".
3. Ensure the phone is charged and select "Ok" in the following window.
5. Wait until the initialising step is finished the continue as below.
7. Follow the connection steps that appear, ensuring that you are holding the relevant button down before during and after the connection phase until the update/repair begins.
Let me know how this goes.
Like I stated, no there is no screen protector / case at the moment. 😕
Will try that tommorow as I've got a lot to back up..
really not looking forward to doing that task with all the foto's settings apps etc etc..
will report back if there is any change or not in a day or two
Ok,
so back with update, performed the repair with PC companion and didn't change anything.
I can't even slide an app from one home screen to an other.
That's a hardware issue, contact your local Xperia Care ASAP
Thanks,
I've filled in the request, hopefully it will be handled fast.. like many others my phone is also my work tool.
I'll keep you updated.
Have a nice weekend.
