Touch problems.
soumilmagin
Touch problems.
I just bought the Xperia Sola, and everything seems to work just fine. The problem is, I installed Temple Run, and the character seems to respond on its own every now and then. Like jumps, slides and change directions. Even after disabling the Floating Touch and the Glove Mode, I am still facing the same problem. I also uninstalled and reinstalled the app. Is there any way I can completely disable this Floating Touch feature, if that is the problem? Also when I was playing Temple Run, the Floating Touch was working on the menu, but then again when I was playing the game, it kept responding on its own.
Should I send it for service? Reset it? Format the SD Card? I'd really appreciate it if someone could help me out of this.
The battery also seems to drain out very quickly. And I am only running Whatsapp and TalkTo.
2 REPLIES 2
Sam
Legend
Legend
Do you have any other touch issues when you are performing tasks other than using this particular game?
shrenikshah
i have also the same problem with temple run 2,Einstein brain trainer due to floating touch..
