Touch problem while charging through USB on computer
DanneLeo
Everytime when I plug in my phone through USB cable to my ACER laptop, the touch does not respond when using the phone, even though I used the original USB cable that is provided with the phone. And I've sent my phone to the repair center because of the same issue. But the problem still persist.  But when I use my brothers laptop which is different model as mine, the touch respons flawlessly. I NEED HELP HERE Slightly_frowning_Face
10 REPLIES 10
Rickard
If this also happens when you charge the phone using the original charger i recommend that you first try making a repair of the phones software in PC Companion. If that doesn't help the phone needs to be calibrated by an authorized service location. Contact your local support (http://www.sonymobile.com/global-en/support/contact-us/) or a service location for assistance in that case.
If it only happens when charging from a certain device it might be a problem with grounding or power supply from that device.
