Touch-button problem with Walkman live
PiperTheGreat
I recived my new Sony Ericsson Live with Walkman, at the beginning of December and all was going great, until some strange behaviour started showing up with the touch buttons. As i understand it, the left button is a back button, and the right, a kind of context menu, that when on the homescreen gives you four options. but mine appears to alternate between giving me this mini menu, and bringing up a keypad... what on earth for i don't know. it seems to link to the google search app. now i understand that ifyou hold this button, the keypad comes up, but i'm not holding it, i jsut tap it. it causes other problems too. It seems to spread to the back button and often both of these buttons become unresponsive. Sometimes going onto the gallery seemed to affect it, although i can't be sure what causes it as it does it outside of the library too. when you're on the library the back button seems to go back two steps ratherthan one. then, without warning the proper function returns. This button behaviour is quite annoying, and i have no idea what is causing it. could be apps i have installed previous? or is there a fault? to my knowledge this phone has not been dropped or crushed. I'm clueless, can anyone help?
Steven
4 REPLIES 4
Jake-SonyXperia
This sounds as though there may be some form of software glitch causing this issue, I suggest using the Update Service to try resolve it.
http://dl-www.sonyericsson.com/cws/download/1/110/61/1315209439/Update_Service_Setup-2.11.9.6.exe
Hey,
I have the same phone I have the same anomalys. It brings up the keyboard while I'm in a game, or both buttons become unresponsive. If you try the link above and it works, let us now, please Winking_Face
Jake-SonyXperia
Definately let us know how this works out for you.
Also experienced this problem. I get this problem, if phone is in not normal conditions, like too much humidity. In normal conditions, it works just fine.
