Hello,
Faulty compact: This phone is always getting hot when ever ireceived message, And after some 3 hours the battery got dead and not going to come back to life agin until i put new battey,it will be showining RED light,please i will need a propper repair to this device and improvement to the phone.
THANKS.
Kemi
Try performing a system repair as this will often fix issues - This will factory reset your phone
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
