I am facing the sd card problem and the echo problem wuth my new tipo device. i tried the sd card solution talked about it some discussion. but after that still the problem persists ..the memory card is partially recognized. that is only few of the content is recognised. rest all still remain in dark. what should i do?
P.S. : Echo problem: the other party hears his echo voice.
UPDATE: After a restart, SD CARD content is still not recognised. i mean the entire content
Have you tried to reinstall the phone software using SUS?
If not I suggest that you give it a try.
