Is there any way to use a specific (list of) contact(s) with a defined SIM on Tipo dual? I want do call my business contacts with business-SIM and private contacts with my private SIM.
Is there any way to change the active SIM automatically depending on he phoned contact and without using the SIM-change-button?
And is there any way to keep private and business contacts in seperated address books? Is there any way to disable SIM <-> adress book-sync when turning on the mobile or switching back from airplane mode?
This is not something that is supported by default unfortunately. My best suggestion at the moment is to check Google play store to see if any developer might have made any application for this.
Hello,
I have exactly the same problem as Retro64. I can't find anything on Google play store. Could somebody (Johan?) recommend some application?
But there is another problem, that is a bug really. Example, I set default sim card SIM1. When somebody calls to SIM2 and I miss the call, I see, that call is missed on SIM2. But when I try to call back to missed call, Sony phone calls using default SIM1 card! It is nonsense. It should call using SIM2, not default card. In this case, I could accidentally call to business contact using my private number, and it is bad. I have to change default card, then make call, then switch back to SIM1. It is really annoying.
Sony should fix that.
In any case, other dual sim phones (not from sony) have address book, where you could mark contact as SIM1 or SIM2, they call back using correct logic (there si no bug mentioned before). It should be default features on dual SIM phones.
kind regards,
Vejukas
