I recently did a required system update to my Xperia acro S by installing the new Android 4.1.2 version. Besides the fact of hating that you eliminated the horizontal and vertical weather widgets and the TimeScape Music Feeds (among other things), the TimeScape "Friends" widget now will not replace the pictures of my friends after refreshing it. Instead, I have to manually add enough friends to cover the otherwise empty squares or boxes on the widget. I really want to have my old TimeScape "Friends" widget back the way it used to be. Is there any chance that you will replace this cumbersome and antiquated widget with the original one?
The horizontal weather widget is till available in your phone. Select to add a widget > scroll to the right and select the weather widget.
Thank you for your feedback regarding the TimeScape widgets. I will pass this on internally.
