hey guys!
using SXS frm may 19 and its jus awesome
eagerly waiting fa JB which shd be available by the end of april.....
frm one week or so, the timescape content is nt at all refreshing......
ive logged out and logged in several times, rebooted phone, nothing is working out...
i request each n everyone to plz guide me out of this situation......
my xperia s is running android 4.0.4.....build no.(........45)
thanx a lot!
hi i've got same your problem and i solved it today
download this file and install the APKs in the phone .
http://www.mediafire.com/?fl4p8f4vpx0jp16
i hope i helped you
don't worry its not protected .enter any username or password
For installing all those apk's, phone should be rooted one?? Because my xps is not rooted, when i install the apk's at the end it says, application not installed (but it did not say any reason for that)..
No my phone isn't rooted and it worked for me
You don't have to install them all only the facebook extention
I just tried, facebook extension installed. But Timescape for Facebook stil don't work after installing fb extension.
It doesn't connect & it will still show connect to facebook.
any other ways / suggestions ?
Thanks in Advance.
I got this problem since 2 months ago, I've contacted sony support and they just said "the problem is facebook itself" ._________.
I reinstalled the whole system and didn't fixed... since the weather widget isn't working anymore I'm starting regret my wasted money in my Xperia S
[EDIT] Just downloaded the apk posted by micheal96 and installed the Facebook Plugin on my Xperia S and now TimeScape is working perfectly
I had this Timescape error for sometime and had pretty much given up trying to fix it,but did what micheal96 did and downloaded the apk and installed the facebook plugin and bingo!! its working again on my Xperia S, now just need the weather widget fixed and everthing will be cool..;)
it doesn't work for me, any other way ?
