Timer Graphic Problem
minz
You may notice that the "seconds" counting down graphic is not properly alligned, not sure if Im the only one who experienced it, it happen all the time after updated to ICS.
Wonder if there is any solution on it or it is a bug.
6 REPLIES 6
Steve3581
Ive never noticed this bug, and have used the timer many times.
Have you tried clearing the application cache to see if it solves the problem?
minz
Tried clearing data in the setting, but no luck on getting this right. Thanks
Sam
Legend
Legend
That's a new one; I would advise running an update/repair via PC Companion given that you have already tried clearing the app data.
Oriba
I experienced that a couple of months ago.  Before ICS was out for my country (UK) I installed a version for a couple of other countries - I think I started with the Swiss one, then moved on to the Nordic Combined one.
I had the same issue on one of those (can't remember which), even though I had re-installed the ICS firmware direct from Sony.
I don't have the issue now on the appropriate firmware for my phone (UK Generic ICS)
VexedBadger
This is far from a new issue.  I had it day 1 of ICS.  If you turn off "Force GPU Rendering" under developer options then the problem goes away (or turn off screen rotation...)
Hope this helps, and you didn't waste too much time performing a factory reset.
Also, why is this question "Assumed Answered"?  I didn't see a fix in the thread.
-- Phil
tr0yquint0
I got the same problem as above. I followed your advise to turn off "Force GPU Rendering" and it works. Thanks for your help.:smileyhappy:
