Hello everyone
I recently purchased a Sony Xperia Z1 and I have a problem, you talk to someone on the phone, there are some times I do not hear the person speaking.
call back if I close and go
can be problem if the person speaking to discontinue lose signal
or a call settings?
There can be a number of causes for this problem, however can you please advise how intermittent the problem is and if you have found it occur only when you use the phone in particular places?
Ok, at least it sounds like more of a sofware issue rather than hardware. With this being the case I would advise running a repair:
1. Download the PC Companion software from http://www.sonymobile.com/gb/tools/pc-companion/
and install it on your PC.
2. Install and open PC Companion then select Support Zone.
3. Phone Software Update.
4. Start.
5. Repair Phone
6. Continue
7. Accept data removal
8. Next
9. Wait for prepare
10. Select Phone
11. Follow the connection steps
I followed all the steps
phone do that before
Talk time no hear speakers start and stop them and hear again
If the repair made no change to the performance then I can only advise returning the handset for assessment by an authorised repair agent sorry.
