Repair your tablet once more with SUS and if that doesn't work, take it to a Sony repair center
Uliwooly is likely correct on how to fix this, however does it happen when you are doing anything in particular?
Take it to the Sony Repair Centre, they should replace it for you.
Had the same problem, they replaced it without a fuss. (I live in Japan).
Do backup your data though.
