The Sony supported SyncML synchronization seem to be removed on the Xperia S ICS update. Can anybody confirm?
Yes, the SyncML option is removed in ICS for Xperia S.
ok, thanks for the clarification.
Any reason behind this removal? Will Sony provide SyncML support via a separate application or do I have to look for other SyncML clients on the market?
I have no info on why this is no longer present, but I think that you will have to use an SyncML application from Play Store if you would like to sync via SyncML.
