Sync problems
delannem
Sync problems
My Neo (ICS) has started to only sync the last three months of my Google calendar. I don't know what I did to choose this, but I really want to sync the complete calendar. I don't have this problem with my Ray, so the problem is located somewhere in my Neo settings.
Does anyone know what I can do to sync all of my calendar and not only the last three months?
8 REPLIES 8
Samuel1
Hero
Which version of ICS do you have in your Neo? Because it should synchronize all appointments in the calendar in version 4.0.4. So, try updating the software in the Neo and it should be the same as in your Ray.
delannem
I have 4.04 already. I can't find any adjustment to set sync amount, do you know where to set that?
Samuel1
Hero
The setting for this has been removed, the phone should always synchronize the full calendar. It seems very strange if your phone only synchronizes parts of the calendar. If you check 4 months from now, the calendar is completely blank?
delannem
It's only my google callendar that's blank - the facebook calendar is ok.
I tried to remove the account from the account menu and then add it, but it's still only the last 3 months that show up.
Samuel1
Hero
Just to clarify, you are synchronizing directly to the google account and not via PC Companion, right?
If you are, you should try making a master reset of the phone and try again. You could also try adding a test-account (just create a new google account and add some things in the calendar and sync it) to see if the problem is related to the phone or to your account.
delannem
I sync directly with google, and not via PC.
I've allready added two accounts, and they sync ok...
Samuel1
Hero
Then there seem to be some issue on the account itself, if the sync works as intended on the other two accounts on your Neo. I have no idea what might cause this actually. Maybe you could contact Google support and ask if they have any ideas?
http://support.google.com/calendar/bin/request.py?contact_type=contact_policy&hl=en
delannem
I think I have to reinnstall isc on my Neo, everything is ok at my Ray, so I suppose it's my Neo. The callendar is on the account that I use as my primary account, so it seems that a reinstall is the thing to do.
Thank's anyway.
