Hi everyone, I have an Xperia T which used to have the same wallpaper for both home screen and lock screen by default. I changed this, but now after an update I can't find the option to change it back so both home screen and lock screen can have the same wallpaper again.
Does anyone know what I can do to restore this option or where I can find it? Thanks
Which build number are you running on? You should be able to manually set the lock screen wall paper as well. Settings > Display > Lock screen settings.
I noticed if you set once a lockscreen wallpaper, then phone and lockscreen wallpapers become independants.
If you want to reset this, you can apply any theme from the xperia theme list. (both wallpaper will reset according to the theme)
Now, if you set a new wallpaper to your phone, you will see that the lock screen will use the same.
I hope it can help
After i got the latest update : 11.3.A..2.23 . I cannot set same wallpaper for Homescreen and Lockscreen in xperia e. there is no option like that.
