Hello everybody! I have an issue when I use the sync zone in order to sync contacts from outlook 2007 to gmail with pc companion 2.10.065
The problem is that some certain fields (like "work 2" number) do not sync at all.
Other fields (like the "webpage" field) sync on some contacts and do not sync on some other contacts.
Is there a workaround on that?
I have just tested this and it seems just as you say that any second number of the same category won't be synced. I think this is a limitation at Google not matching/supporting the exact same PIM filed's.
However I could not replicate the problem with the web page field.
